Filler neck hose for a 1984 2.0 carbed?
neinnein_nein
30
new york
ford ranger
soon-to-fire up 2.3 turbo lima
3!!
Not kidding, I can’t find the part on eBay, Bronco graveyard, autoandart...
Where can I buy this thing? or is there an easier to find equivalent that ll fit?
gungfudan
19
Mississippi
Mazda
N/A
N/A
I am assuming the gas tank filler neck hose?
gungfudan
19
Mississippi
Mazda
N/A
N/A
tomw
46
toenails of foothills NW of Atlanta
lima bean
vertical and above ground
Does LMK carry this item? They have parts for a lot of older trucks. An alternative is the use of the 'blue' hose or other fuel proof hose of the correct diameter along with substitution of some length of tubing if needed.
Sometimes you can look at other hoses, and either cut them to fit, or cut off sections with elbows, etc that you can then join together with metal tubing to approximate what you need. I have successfully used cut off hoses for upper/lower radiator, not having to find a fuel filler hose so far...
tom
neinnein_nein
30
new york
ford ranger
3!!
hey thanks yes I got one for a 87 and it seems to be compatible. not a complicated part, but i found it odd that you can't order a 1984 specifically. gonna put it in this weekend when i take care of some rust on the frame and replace my old, loose, rusted bed bolts with new ones.. tired of all the squeaking.
Bird76Mojo
1,265
IL
Let us know how it works when you're filling it up at the gas station. On my 87 Ranger, the fuel will splash out at you right as the tank reaches the full mark. Annoying as hell, and it'll run down the side of the truck if you aren't careful. It doesn't shut the pump off in time like on all other vehicles.
