Finally. A permanent power steering whine fix!
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
I’ve had my share of fords over the year’s. Every single one has the horrible steering whine. Mercon v flushes. New pumps. Multiple bleed procedures. Never could seem to get the noise to go away.
Ive seen in the tech articles about using a Saginaw pump to eliminate the noise. Problem is, those pumps are impossible to find. And not cheap when you do. So I spent hours researching. And much to my surprise. I came across a company that had a fairly simple solution to this age old problem.
This company machined an adapter That bolts to your existing power steering bracket. And allows you to use the modern Saginaw TC pump. Found on the 2000s Jeep liberty’s. They advertise it for a 4.0. But I personally just installed one on my 3.0. And it worked perfectly. And it’s DEAD SILENT. All the lines mounted right up. It fits perfectly. And the instructions were super clear.
im not affiliated with them by any means. I just was very pleased with the results on my own truck. And wanted to share with you guys. Check it out!
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Awesome find, so all I would need is this adapter and a '00 jeep liberty pump?
86isuzu
TRS Member Since 2003
Firefighter
EMT / Paramedic
ASE Certified Tech
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Sure looks that way. 2002-2006 Liberty with the 3.7 V6.
But only guaranteed to fit 98-00 Ranger.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Doh mines a '93 nevermind....I knew it was too good to be true.
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
A little research over at RockAuto might get your hopes up again:
1998: 2.5, 3.0, and 4.0 use Motorcraft STP55RM
1993 2.3 and 4.0 use Motorcraft STP25RM. Rockauto doesn't have Motorcraft for the 3.0. They have other brands and they look the same as the Motorcraft, but part number does not match the same brand for any of the other engines above. Who knows, for the 3.0.
The $64000 question is, "What is the difference in the Motorcraft STP55RM and STP25RM?". I don't know but they sure look the same in the pictures. I wouldn't doubt if the difference is internal only.
RangerFabWorks
715
302
If I had to guess. It’s probably the pressure fitting in the pump. Which you have to swap out on the Liberty pump anyway. So I think the worst thing you would have to do. Is change the pressure line. Everything else should fit fine.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,575
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
steering box vs. rack and pinion...
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Thanks my hopes are back up lol, Im gonna look into that!
It would be awesome to retrofit rack and pinion.
gw33gp
540
Costa Mesa, CA
4.0 SOHC
33"
I keep hearing about the infamous Ford power steering whine but have never experienced it. I have owned Fords since I was 16, starting with a 1955 Mercury (just an upgraded Ford) that I drove in High School. I must be very lucky with driving Fords for over 60 years.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
My F150 and ranger have both always whined, but work fine. Occasionally I will bleed it and transfer in some fresh synthetic atf (which is what they say to use). It will go away for a bit after this procedure, but only for a short time, then the whine comes back. I just live with it.
svtcards
138
Lyman maine
302
3'' front 4''back
Good
Good to know.by the way would u know why there so many bends and turns and up and downs on the 80s power steering system steel tubing.l?i want to clean up all those bends and twists but wasn't sure they were that way for a reason?
Bgunner
1,097
Western Mass.
Ford/Ranger XLT
225/70/R15
From what I have noticed mid 80's to mid 90's were the most common Ford pick-up and vans that had the power steering whine. IF your car is whining the pump is going or the fluid level is low but for the trucks it was a very common issue with no harm being done. My Ranger whines and so did my '90 F150 with the 5.0l it's just a ford power steering pump thing for the trucks and vans.
Junk Collector
Truck of Month
4,860
Rapid City SD
Good
Depending on the vehicle, those miles of steel tubing act as a fluid cooler. F series trucks in the 80's had a big wrap of it that went down to the engine cross-member and made a big loop. RBVs aren't quite like that, the amount of steel is negligible and I imagine it's bent the way it is to give the line a little bit of flex when the engine moves and to give the lines some space between each other.
svtcards
138
Lyman maine
302
3'' front 4''back
So if I try to clean it up it won't affect much if anything at all if I do it right?
svtcards
138
Lyman maine
302
3'' front 4''back
I mean getting rid of the bends and clean it up a bit I mean?
