Fired on the first lick
Junglejoe
66
Columbia Missouri
6.0
Finally started the truck for the first time. Still have to clean things up under the hood, get the exhaust done then have it dyno tuned. Probably have to switch to 30 lb injectors, well see
This is untuned, no 02's, stock maf, 24 lb injecters, no exhaust pipes, PATS transfered over to my truck from the donor
Twisted wedge heads, ported upper and lower intakes, ported tb and an Anderson Ford cam.
2drxploder
436
usa
ranger
347
lower
235 on 15s
nice! sounds a lil nastee
Junglejoe
66
Columbia Missouri
6.0
Thanks.. "hopefully" it does good on the dyno with some decent numbers for a daily/travel truck. Pretty sure it will yield the results I'm after which is the magic number 350 to the tire. Stock bottom end explorer engine
8,374
(y)
Sounds good, bit of a lope :)
jbeach3101
4
Illinois
302
flipped rear shackles
Just a touch of lope lol.
