First Gen grille guard width
17,972
SW Iowa
Anybody have a regular Ford accessory one handy to measure the outside-to-outside of the two big main vertical plates for me?
Looking at you @Shran
Junk Collector
Truck of Month
4,858
Rapid City SD
Unfortunately I no longer own one, the only grille guard I have on a Ranger is aftermarket.
Ramcharger90
1,708
N/A na
306, Bcam,
17,972
SW Iowa
17,972
SW Iowa
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I would think it would be the same as the outside width of the frame. I'm only guessing because most of the push bars on older trucks bolted to the outside of the frame.
Are you trying to make one? It looks very basic.
IIRC, they were 3/16" or 1/4" plate and the tubes were 2" x .180 wall.
17,972
SW Iowa
I have the headlight guards to go on the outside of one so I would like to match the width for those.
And I have a receiver mounted winch plate that needs trimmed to fit inside of whatever that ends up.
kunar
131
Toledo, Ohio
5.8l
It's 25-3/4" on the outside, 25-1/4" on the inside, plates are 1/4" each. They attach to the truck by 1-1/2 x 1-1/2 x 3/16 angle iron brackets, 1-1/4 long. The brackets bolt to the frame with the bumper bolts, then bolt to the outside of the plates. The tubes on mine are 1-3/4" diameter. They've been replaced (originals rotted out) but I have no reason to believe the originals were any different. If you need more info, let me know. I could probably draw up the plate and dimension it so you could make your own, or send it to someone to be cut.
17,972
SW Iowa
If you would want to dimension a plate that would be awesome. Any close up pics would be great too.
kunar
131
Toledo, Ohio
5.8l
I have to get a CAD computer set back up, among other things, but i'll try to get it done sometime. Hopefully you're not in too big of a rush.
17,972
SW Iowa
Not really, with the width I can freestyle the rest of it if I have to.
I might have to anyway, not sure my daylighters will fit with the Ford tube spacing.
holyford86
Some guy with a problem
638
Plattsburgh, NY
many
33x12.50R15
If they're the common size that is copied by everyone, they'll fit
17,972
SW Iowa
The Ford ones are rectangular, mine are the old school round ones.
holyford86
638
Plattsburgh, NY
many
33x12.50R15
holyford86
638
Plattsburgh, NY
many
33x12.50R15
To add to my previous post
