First time Ranger owner
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Welcome! Good looking stepside.
HWJ2675
10
Knoxville tn
Ford ranger spl
StephenF
35
East TN
Ford Ranger XLT
2.8 V6
Welcome neighbor. Personally not a fan of the wheels, but as long as you like them well done. Maybe if you can get a Ford center piece instead of the Mustang it would look better in my opinion.
HWJ2675
10
Knoxville tn
Ford ranger spl
Welcome. Personally not a fan of the wheels, but as long as you like them well done. Maybe if you can get a Ford center piece instead of the Mustang it would look better in my opinion.
Yes I agree with you! Would you happen to know if that is even Possible?
TIA
superj
2,654
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
welcome!! i think if you lowered that truck and put some larger sway bars, those wheels would be perfect. the shorter sidewall leaves a bit of gap, rightn ow.
what are your plans?
HWJ2675
10
Knoxville tn
Ford ranger spl
Definitely planning on lowering! Just trying to find what's the best way for a factory ride. Any suggestions? Possibly swapped with 302 n t5 later
superj
2,654
ranger edge
none
none
235s
i have no idea. my 05 has the torsion bar front suspension and its very hard to lower so i am jsut leaving it. does h&r or eibach make anything for the ranger? those are the main brands i use on cars when doing suspension stuff. than its koni or bilstein shocks/struts.
if you don;t have a rear sway bar, get one from the junkyard and you will feel an immediate improvement
HWJ2675
10
Knoxville tn
Ford ranger spl
This truck actually has a sway bar in the rear I assume because of being the splash edition. I've looked at several different kits and I'm just undecided 😕
superj
2,654
ranger edge
none
none
235s
yeah, that is how mine is because mine is an edge.
h&r or eibach are both really good, if you are looking at those. i try to go as low as possible so (and i don't know if this is possible since mine is torsion bar) if the front springs sit on a strut, instead of on a spring perch attached to the control arm, maybe you can also shorten the strut housing for an additional inch or two or lowering? thats how i have done some bmws for racing, in the past.
Robertmangrum.rm
Wannabe Overlander
1,635
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
TIA
It's possible. I had a set of mustang bullet wheels on my Sport Trac. They had the fordh center caps. I actually picked them up at a swap meet during the NMRA event in Bowling Green KY.
HWJ2675
10
Knoxville tn
Ford ranger spl
Awesome! I'll give it a look and see what I can find
