fog lights
2011RangerSport
4
Florida
Today early 4:30am was driving along and the fog lights stopped working. Other than checking fuse box is there anything else related to this? 2011 Sport thanks
8,373
Welcome to TRS :)
Check fuse 31 in engine bay fuse box, there is also a Fog Light Relay in engine fuse box as well
The Fog light switch is not directly connected to the Fog light relay, it is connected to the Body Computer(SJB)
When switch is turned on SJB gets that "signal"(12volt) and then activates(grounds) the Fog Light relay
Hopefully its just the fuse :)
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Moved this one to the lighting forum.
2011RangerSport
4
Florida
yes I did check fuse and it is still good.....the switch faulty maybe??
Josh B
1,988
Oklahoma
Hey 2011, welcome to TRS :)
8,373
Unless the switch is obviously damaged then no, probably not the switch
You can jumper the relay to make sure fog lights work
SJB connection is more likely
Here is the wiring diagram, 2009, 2010, 2011 will be the same, Rangers were coming to end of production so Ford wasn't changing things, lol, just using up what they had
Josh B
1,988
Oklahoma
When did they stop making Rangers?
sgtsandman
Aircraft Fuel Tank Diver
12,779
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
