Ford Ranger Tail Gate Assist DIY
Pilot Laslo
12
Oklahoma
Hello
I have been searching for a tailgate suspension for a Ford Ranger, with no luck, below I will describe how i made one for my 2002 Ford Ranger.
Original Poster: Pilot Laslo
Difficulty: 3 out of 10
Time to install: 1 Hour
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation: Modify a 2009-18 Dodge Ram 1500 tailgate assist to work on your Ford Ranger
Tools Needed:
-Drill
-Screwdriver
-T40 torx
-Drill Bits
-Vice Grips
Parts Needed:
- Ram 1500 Tailgate assist https://www.amazon.com/gp/product/B07XC22SBJ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
- Large Self Drilling Screws
Steps 1:
Drill Holes for self tapping screws, then attach plate with screws as seen in photo
Steps 2:
Remove the driver side brake light, Then remove the bottom bolt holding tailgate support wire, then with vice grips grab the bottom latch square nutplate inside brake light housing and yank it out.
Steps 3:
insert the small round ball for suspension, then add nut (not included) to back side.
Step 4:
Add suspension to the 2 round ball, and your done
Please let me know if you have any questions.
RRack
Law Enforcement
San Antonio, TX
Ford/Ranger
I see now the ball stud in the pics on Amazon. However I got two metal plates with the studs welded instead of the threaded stud.
RRack
Law Enforcement
San Antonio, TX
Ford/Ranger
Sorry for bugging you and I know this is old but worth a shot. Did you replace the regular cable support too or just rely on the other cable on the right side?
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Laszlo hasnt been on since Jan 3...
sgtsandman
Aircraft Fuel Tank Diver
12,764
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
All the installs I've seen do not replace the support cable. It's just there to slow the rate of decent of the tailgate. Usually, they allow you to release the tailgate and just let it drop. The support cables are still needed to hold the weight as you load and unload things.
  • ZMan
