Junk Collector
Truck of Month
- Mar 4, 2008
- 4,857
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Never been much for Explorers because it seems they are all either really rusty, nasty color combo, trashed, or have an A4LD with electric 1354 t-case... well... I ran across this one and had to have it!
The story I got was the PO was driving back to town, it started losing power, smelled bad and was "overheating." The guy thought he burned up the transmission so they hacked the exhaust off, thinking it might be a plugged cat.
I bought it for $200 after hearing it run, figuring it would be a good parts donor if nothing else... it has ALL the good parts, M5OD, manual t-case, manual lockouts, 3.73 geared 8.8 with a limited slip, really nice blue interior, and not a ton of rust! Just the dog legs are gone, like most are, easy fix there. Even the tires are in great shape.
I put a clutch, shifter bushing kit, rail plugs, slave cylinder and rear brakes in it last weekend and have been driving it a lot. I still need to put exhaust on it as it is pretty much either cobbled up junk that I had laying around and the rest is rusted through. Runs and drives great, I am shocked! The dang thing doesn't even really have any major leaks!
The plan is to leave it stock, perhaps run a set of 31's is all. I needed something nicer to drive around town. Just had to brag a little!
