Frame rust how bad is it?
Lewy
East Brunswick, New Jersey
Mazda
Could I get away with just rust proofing?
Would like to be able to tow using the v6 4l at around 5000 pounds. Only this part of the frame is this bad. Next to the gas tank.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Looks a bit sketchy to me since your flexing it by hand...
ericbphoto
Overlander in development
16,650
Wellford, SC
3.0L
6"
That frame is staring you right in the eye and saying...
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Gas tank area always collects crap so this is more prone to happening.
I'd address the issue before towing 5k with it.
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
If all you were doing is driving it...id say run it.
But towing that kind of weight is going to put alot of stress espicially in that general area due to twisting.
It *might* be ok but i wouldnt try it. Its awful spongy.
Josh B
1,987
Oklahoma
it won't just be on the surface either, but the bolts back there are also rusting underneath. To properly repair that would take a complete teardown and refurb, probably including a replaced frame
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Nah, pull bed, gas tank, and spring hangers, grind and plate, paint and reinstall everything.
Check out last page of my build thread in my sig to see how I did it. Overkill as hell, but same concepts with thinner plate would be fine
Bird76Mojo
1,265
IL
That won't work for everyone, in every case.
Either way, there's really only one course of action. Start chipping away at it until you see just how far and how deep the rust goes. Get out the flatblade screwdriver and start chipping away...
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
True that.
I was more thinking that complete frame replacement was excessive, but the screwdriver comment gives me flashbacks to one of my parts trucks. Looked fixable, but was mush.
Find a new truck.
Lewy
Mazda
Ah damn. Got this truck because I was interested in fixing something up without knowing anything about vehicles. Still would prefer to be able to fix the frame if possible. I cleaned it up and did find one hole in that area and took a few pictures.
I had originally planned on removing everything possible on the frame and rust proofing it. I was hoping it was a small enough section of the frame that I could cut the piece out and add a new one in.
Ignore the brake line to the brake caliper. I'll fix that
Before
After
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I definitely 100% would not tow with that thing... it's fixable but is the truck really worth the effort?
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
Yes. If it keeps it from being crushed and turned into an EV.
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Truck is fixable/usable, but I wouldn't risk towing with it. I'll bet that frame cancer runs deeper than you think.
ericbphoto
16,650
Wellford, SC
3.0L
6"
I just re-watched the first video he posted. When I see that frame flex in his hands, it scares me. In my opinion, it needs some serious repair/strengthening. But replacing the whole back end of the frame would be better, IF the front half really is good.
