front axle seals leaking
joe93
front axle seals leaking only during and after axles are engaged at the hub.
The auto hubs, mostly the right side seems to be kicking in and out whenever i make a tight or semi tight right turn. will changing to manual hubs help solve the leaking or will i need to change everything including u joints? I failed to mention it's a 93 ranger.
Wicked_Sludge
43
Westport, WA
3-point-GO
changing your hubs will not stop your seals from leaking.
if your u-joints arent bad, you can replace just the axle seals.
changing to manual hubs will fix the locking/unlocking problem.
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
8
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
if you change out the auto hubs to manual ones that will solve your pop in an out of 4x4 now with the seal your going to have to change that..you shouldnt have to change your u joints unless their bad.
