Front bumper mount replacement
MJ'sBlkBII
Harker Heights, TX
Is it possable to remove the rivets that hold the front bumper mount with a good chisel and hammer? I can't get my cutter out to the P-N-P so this would be my best bet. One of the family members hooked the bumper on a pole and pulled the bolt through the hole enlarging it, so I can either replace the mount or try washers which doesn't sound like a very safe idea.
tomahawk350
26
Johnstown, PA
Ford Bronco II
no clue what you talkin about..... RIVETS?
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Pretty sure those are carriage headed bolts. The bumper is not held on with rivits. Unbolt the brackets from the frame, remove the whole assembly, and you will see where to take the bolts loose.
MJ'sBlkBII
Harker Heights, TX
The bumper is off. That is not the issue. The frame end that it mounts to is what is broken. It is held on with 4 (?) rivets. I suppose it could be called a braket, but I wouldn't see it as such.
