Front End Noise... Help!
terre
1998 MAZDA B3000 EXTENDED CAB 3.0
I been dealing with a grainding noise in the front end when i drive between 25 and 35 mph after or before that, noise goes away. Recently i rebuilted my automatic transmision and the machanic told me the rear end was making noise and i rebuilted the differential (the gears were damaged). But still same noise is still there. I checked the front wheel hubs and seal there are ok, one of them seal was damaged and i replaced wheel hub and seal and still same fu^$#& noise is still there.
My drive shaft ujoins are bad and i know becouse when i change reverse or drive i can hear i drive shaft noise. My question is :
The u joins can possible make this noise between 25-35 mph?
It's been a pain in the b#%%$!
Help please!
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
U-joints make a squeaking, or chirping noise when going out. If you have an aluminum driveshaft it may make a little noise when shifting.
I would guess you have bad front wheel bearings. Jack up the truck and spin the front tires, check for notchy or grinding feeling.
