Front end swap on my 94 mazda
Redneck_Offroader
jeddore, you blink and you will miss it
mazda
v6 4.0
NEED HELP! Front end swap on my 94 mazda
hey, i got a 94 mazda 2wd and i wanna do a front end swap for a 4wd, question is, will a ranger front end fit on the mazda with out major changes, i need to know so i can start project redneck offroader THANKS:icon_welder:
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
The entire engine crossmember needs to be removed and swapped with one from a 4x4 truck before you can bolt any 4x4 components underneath the truck.
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Pretty much.
AD
Redneck_Offroader
mazda
v6 4.0
now my next question is will a front end from a ranger fit my mazda, i found one, its a 94 or a 95 cant remember with motor, tranny, t-case, the whole 9 yards, and if it will fit my truck i can start my build
alaskan155
6
washington
FORD
7.3l/4.0l
yes 83-97 4WD ranger, 91-94 exploder 2wd/4wd(just need ds bracket for 4wd, cross members are the same), 83-90 bronco II 2wd/4wd same as exploder
AllanD
TRS Technical Staff
135
1987... sorta
'93 4.0
Actually you very specifically want a crossmember off of an '89-up.
The difference is the location of the holes for mounting the clips that
the fuel lines run through.
AD
