Front End Weight
cmequestionu
16
Federal Heights, Colorado
Solid Axle Swap 4x4
~10
Ok, so I am doing a solid axle swap on my '00 ranger. I am to the point where I need to order front coil springs. The 98+ rangers didnt come with coil springs I need to know what the front end of the 98+ 4x4 4.0L weighs in order to get springs made. My truck cant move so I cant get it to a scale. Any help would be appreciated.
Will
514
Gnaw Bone, Indiana
Toyota
My guess is 3,600# total with 1,200# on the rear and 2,400# on the front. Plan for 1,200# per spring at whatever spring height you need.
3,614
Check your certification label. There should be a number labeled GVWRF. That is the sprung weight the front of the truck is rated to hold.
cmequestionu
16
Solid Axle Swap 4x4
~10
I know about the gvwr. Problem is it only tells you how heavy the truck will be at max capacity. I need to know how much it weighs normally. If I had spings built for max capacity all the time it would either sit too high or be a rough ride. Ive taken the truck to the scale before, it usually came out to 4480# with me and my girl. If I knew what the weight balance was I could get a good idea. Thanks for your help so far.
3,614
There are also ratings on the label for GVRWF and GVRWR. Front and Rear.
The GVRWF is the front axle weight, what is slung on the front axle. The GVRW is the loaded weight of the whole vehicle.
cmequestionu
16
Solid Axle Swap 4x4
~10
The cert on the door says 2850. I took my bro-in-law's 02 ranger 4.0 4x to the scale and the front read 2660 with both of us in it. He has the newer 4.0 I cant imagine his front end weighs 200 less with passengers than mine.
Mac
183
C. Wisconsin
2000
199
Mine both (2000 4x4 ext cabs) say 2710#'s but that's the rating, not the actual weight.
Dave
3,614
So go with his front end weight. It's the same truck, and the engine block is the same. The weight difference of the two 4.0s is negligible.
You didn't tell us you had that number. With no other information the Front rating is at least a starting point.
cmequestionu
16
Solid Axle Swap 4x4
~10
We had just gotten back from the scales when I posted that weight. His truck has the same gvwrf as mine.
No members online now.
