Tulsa Time
- May 22, 2008
- 1
- Coweta, Ok (Tulsa area)
- Ford
- Engine Size
- Was 3.0, IS 4.0
I just bought a '93 Ranger 4x4. It's the first 4x4 I've ever owned. During inspection I've found a few issues that bring questions to mind.
My most immediate question is about the auto locking hubs. I don't plan to replace them anytime soon so I would like to service them. I am in the process of servicing the bearings now. I've learned a lot from the Tech Library (That's where I learned to check the front bearings. Sure enough they are a bit sloppy) and I have a Haynes manual, but haven't found anything on the disassembly of the hubs. Maybe I just haven't looked in the right place yet.
My next question is about the front drive shaft. The slip joint has some lateral movement. I doubt this is normal but I thought I would ask. Is there a bushing kit or something for it or do I need to replace the whole thing?
The passenger side axle seal at the front diff is seeping a bit. There also seems to be a little lateral movement here. I assume I will need to remove the center section to remove the axle (c-clip) in order replace the seal. I can figure that out but is there a bushing here that can be replaced? I know from experience (i.e.: torque converter seals, trans output seals, etc) that lateral movement can, and often does, cause premature seal failure.
Any help is appreciated.
