front pump
ma92ranger
i have a 92 4x4 with a 4.0 and the trans is a a4ld not to sure but i think the front pump is goin bad every now and then when im slowing down i can here a pump whining sound anyonen ever had this problem :icon_confused:
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Have you checked the dipstick? If the level is low... If the fluid is dark...
70roadrunner
8
sedro-woolley, Wa
1970
194
plymouth
2.8
low fluid or an internal leak
70roadrunner
8
sedro-woolley, Wa
1970
194
plymouth
2.8
and check power steering fluid
ma92ranger
its new just done a filter change about 5000 miles ago and its not over full and the power steering is all new the pump and lines the trans only has about 20000 miles on it
Andy D
10
Marshfield MA
The Rat
4.0 OHV
The first thing I check when I hear noises is lube levels. Also, how is the center bearing on the driveshaft? If the levels are OK, then the noises are probably not so expensive.
3,614
ma92ranger
driveshaft is new and fluid is fine this is why i cant pen point it :icon_confused:
