Front Recovery Points
17,972
SW Iowa
Barring a new front bumper anybody have any clever ideas for front recovery points on a '91?
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,793
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
0.5" flat bar drilled to use the existing bumper mounts and a hole cut in the bottom for hooks or straps? I'm not sure what aftermarket companies use to make theirs. As if they heat treat them after fabrication. Think a 2" or 3" X 0.5" bar dropping down from the frame to where you can clear the bumper and hook something to it.
17,972
SW Iowa
I was thinking something beefy tying both frame rails together with hooks/loops on it.
It isn't for my truck obviously and I don't think he wants to loose the stock looking bumper. I think the airdam would have to go though.
The factory bumper brackets have proven less than resilient for recovery...
sgtsandman
12,793
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
What about loops poking through the opening in the bumper like in the newer old model Rangers? Is there room to poke some in there? I think I know what truck you are speaking of. I don't remember how much room there was in the opening.
broncc
571
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
I have experience in this! Please forgive the awful camera.
I used 2" square tube, 1/2" round stock and I think 3/8" bar stock. This was my first welding project and was more for welding practice and learning about how metal behaves. I am happy with boxing in the frame with the square tube and the triangular bar stock braces. The next hooks will require thicker round stock because I was able to bend them pulling someone else. I do not believe it is necessary to double up the square tube to drop the hooks. It clears the spoiler just fine if you make them long enough. This cost $30 in steel and used existing holes in the frame.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
3 bolt hook...notch chin spoiler...
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Exactly like under my b2
17,972
SW Iowa
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Under..
the m mounts on the bumper are ram....
but standard hooks are under....on the frame...bobby kept trying to smash them off....
17,972
SW Iowa
Under..
OK. I just saw the Ram ones.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I should have just put one on the side like I was going to...on the passenger side you use the existing slot and drill one hole....
It puts the hook at an angle and allows the strap to cradle the bumper....just sux fishing the nuts in there taped to a wrench.
17,972
SW Iowa
Any way to get a pic?
Junk Collector
Truck of Month
4,860
Rapid City SD
I used Chevy tow hooks on my '87... the kind you typically find on 88+ half ton and larger pickups. I mounted them to a piece of 4" angle iron (1/4 thick) that was attached to the bottom of the frame rails. I cut little slots in the air dam for the hooks to slide through. It's pretty stout and was pretty damn close to free.
I like the Chevy tow hooks because they mount flat and therefore discourage straps from slipping off.
17,972
SW Iowa
I have a set of loops off a 97-03 F-150...
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I would have to remount it.....but you can get the gist I think ...
I have a three hole on my ranger...the lower bumper bolt hole and the rear most hole can accommodate it with just a notch of the air dam which you have to pull of course...then reinstall....
