Front wheel wobbles???
poomero
23
Oregon City
I have a 95 4x4 and I noticed the passenger side front wheel wobbles. Would this be caused by the bearings being bad?
superj
2,700
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
It surely could be. But, tou need to lift the truck so that wheel isnt in the geound and check the bearing for play, and also the control arm bushings steering linkages. And the other stuff too.
Jack the truck from the frame so the suspension on that end hangs freely and you can check all that stuff
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Don't you mean when you jack it up you can feel movement in the wheel?
Or it wobbles while driving?
Uncle Gump
Token Old Guy
13,561
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Chances are the bearings are loose or worn out
Just a note... when someone says wobbles... I think of the wheel spinning and it shows excessive runout (wobble).
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
