Ranger305
- Mar 27, 2011
- 23
- Tennessee
- Ford
- Engine Size
- 3.0 Vulcan
Maybe I have finally found the source of my '92 3.0 struggling under load.
Truck starts and idles fine as well as rev with no load. On the road, it feels sluggish on takeoff or climbing hills and often feels like there is a miss/extra cylinder kicking in. It does feel better sometimes, but has gotten much worse lately. It has been a work in progress since I swapped the long block 3 years ago.
I put a fuel pressure gauge on it and got the following results. I recently replaced the fuel injectors(originals had 260k, so it was time) and the below readings mirror what I found before, so I don't suspect a leaking injector.
It has new o2 sensors as I was getting codes and they were due for replacement anyway. The TPS is also new. Distributor was replaced a year or so ago with new aftermarket because the bearings went out in the original. Plugs and new motorcraft wires have 4k miles. Just swapped the cap since the old one had pitting on the internal contacts (was a cheap one with aluminum posts). Coil is new within the last couple years.
Fuel pressure readings:
Key off/engine off - 0
Key on / engine off - blips to 10psi or so then back to 0. If I trip the key/pump a few times, it will climb past 40, but after a couple seconds of Key off, back to 0
Engine running- 30psi stable
Engine running, vacuum line to FPR removed and plugged- 40psi
Engine running, blip the throttle- quickly goes to 35psi, then drops to 28-29psi
Engine running at 2000-2500rpm- 28-29psi.
Pump is an airtex aftermarket that is maybe 10 years old. FPR was replaced around the same time.
I suspect the check valve in the pump assembly is likely bad. Would that cause running pressure to be a bit low and cause issues under load?
