hddave1
- Apr 19, 2009
- 0
- kentucky
- ford
- Engine Size
- 302 v8
im at the point in my v8 swap that i need to concider a fuel pump..i know alot of ppl run ele. but i would rather run a machanical fuel pump..the tech page say to use 1970-1973 Ford Econoline van with power steering..so i looked it up at autozone and this is what i see..... http://www.autozone.com/autozone/parts/Airtex-Master-Fuel-Pump/1972-Ford-E100-1-2-ton-Van/_/N-ipojrZ8vcz2?counter=1&itemIdentifier=193052_0_0_3492&vehicleIdForService=144341084 ....is this correct...now the 302 i have has a block off plate installed where the pump used to be...i didnt put it there so when i pull it off to install the pump, should there be a rod in there or should there be a fuel pump excintric on the cam..i just want to make sure that i have what is needed in the block to use the mech. pump..thanks
