- Jan 28, 2023
- 49
- Brooklyn Park, MN
- Ford Ranger
I need that fuel sending unit that AndyB has. Anyone know where to find one? I’m striking out.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
That's normal. They where not that accurate when they were new. And you will always have about a 3 gallon reserve that the sending unit will not show. As crude as the gauge is, + or - 2 gallons is not bad when the needle hits empty.I ordered one as well. Now they have four.
Can the resistance be read any other place than just the sending unit itself? Mine will read full when full but reads empty when there's about 5 gallons still in the tank.
I wouldn’t replace yours at this point, unless you have to drop the tank for another reason. Here’s a write up I did about calibrating the instrument voltage regulator after having replaced the gauge and sending unit:I ordered one as well. Now they have four.
I let the needle reach "E" and also noted the mileage on the trip odometer. When I did go fill it, it took 13.5 gallons so I now have a pretty good idea of what my 'reserve' is.That's normal. They where not that accurate when they were new. And you will always have about a 3 gallon reserve that the sending unit will not show. As crude as the gauge is, + or - 2 gallons is not bad when the needle hits empty.
