Fuel tank question
nate_378
Law Enforcement
Texas
Ford Courier
My brother has a 1980 Ford Courier with the 2.3l and its the short bed. The fuel tank is rotted out on it and am looking for a replacement. Does anyone know if they shared that tank with any other models? Summit shows to have one, but the picture doesnt look like what we pulled from the truck. So trying to see if maube a Ranger tank would fit or if wed be better off going with a boat tank setup.
8,372
Welcome to TRS :)
Ford Couriers were all imported so there won't be crossover parts with Rangers or any built in US vehicles
But a Ranger tank may fit, just by luck
So best bet is to guesstimate gallon capacity then google that, i.e. 16 gallon gas tank
They come in all shapes
Not sure what you mean by "boat tank"?
Go here: https://www.car-part.com/
1980
Ford Courier
Gas tank
YOUR Zipcode
Search
Short box
Search
See what comes up and where it is
Ford Courier was first imported in 1972 and ended US sales in 1982(because Rangers came out in 1983), 1st and 2nd generation Couriers, 1972-1976, 1977-1982
There were 3rd and 4th generation Couriers sold in other countries until 2007
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Or put a fuel tank in the rear between the rails.
nate_378
Law Enforcement
Texas
Ford Courier
Thanks for the replies. Its right at around a 15 gallon tank, so ill see what i can find.
Junk Collector
Truck of Month
4,853
Rapid City SD
Bottom feed aftermarket fuel cell would be an easy fix or a top feed with a low pressure electric pump.
