full hydro
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
Original Poster: NMB2
Difficulty: 6 out of 10
Time to install: 8 - 12 hours
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation: ok so this a writeup on doing a fully hydraulic steering setup on a RBV. Of course things will vary with different model trucks and axles and steering setups, but this is a general guide to the install.
Tools Needed:
-General hand tools such as wrenches and sockets (air tools recommended)
-Bench vice
-Cut off wheel
-Wire wheel
-Welder
Firstly, I personally chose not to peice a kit together like some do, instead i called PSC to build a kit.
This kit in specific cost me around $750 and included a 12.9 Eaton orbital, 2.5" x 8" ram, plenty of pressure and return hose, lots of fittings (extras), mounting bracket, steering column adapter, 4 mounting Tabs and 3 stickers!
The first thing i did was remove all of the old steering parts including steering shaft, steering box, drag link and powersteering pump hoses, and wire wheeled the frame rail inside and our all around the greasy areas and parts i planned to weld to.
The bracket they give you is designed to mount onto a 1 3/4" tube, and due to the size of the orbital valve it could not be mounted flat onto the frame. with how narrow the frame rail is in that area and given the fact that I needed to keep the valve as low to the frame as I could I decided to take a peice of 1 3/4 and notch it to hug the frame.
Basically I just ran a bead across the front and back of the bracket onto the frame, and about 180* of the tube that hugs down onto the sides of the frame rails.
The next thing i did was put the Heim joints onto the ram and clamp the tabs on with bolts so I could figure out how to position tabs. On my setup due to the height of my steering decided to mount the body onto the diff cover. After it was mocked up It was fully welded.
Take note that you must mount the ram on the stationary body side first, after you do so pull the plugs from the ram so you can extend it to 1/2 stroke, then mock up where the tie rod side tabs will be.
Putting the orbital is pretty straight forward, it comes with plugs in it which you remove and you put the straight fittings into. The kit did not come with instructions but you can find online the port designations for pressure, return, left, right. The valve can be mounted in any position.
Putting the lines together is also very easy. They send you a length of pressure line which is about 3ft more than enough for what i needed. Installing the fittings onto the pressure lines is also pretty straight forward. I believe a bench vice is required. You take the outer casing and thread it onto the hose until it bottoms out, you then put the casing into the vice and thread the 90* fitting into it, which flares out into the hose. Having some thread exposed is acceptable but i bottomed them out as well. The nice thing about this style fitting is that its removable and reusable. For the stock power steering pump pressure line, you just cut the hose off at the box end, and install one of the PSC fittings.
Here you can see the fittings, and I kept the stock power steering pump line. The blue anodized fitting designates return line. I have mine running into the cooler, and then the cooler goes back into the pump.
At this point You can route your lines down the ram, extend the suspension to full droop and give slightly more slack than that, I made loops in the end of my line to act as a damper so it wasn't dangling but could extend more if needed.
Once that is done its time to tie the lines up. I went to Fastenal and found some giant zip ties which were way to long but they are wide and thick, as you can see in the pictures I used those to hold the lines together.
Once all the lines have been put on and system is ready, fill the pump, start turning the wheel left and right, lock to lock... it helps if you have a buddy to keep pouring. Repeat this 10-15 times. You should start to get movement. Continue these steps until it stops taking power steering fluid. start the motor... continue going lock to lock another 10-15 times until it is fully responsive and your buddy can quit filling it. Once this is done your system is bled. Also make sure to do this with tires off!!
Also when doing this swap I HIGHLY recommend converting to a Saginaw pump, the stock ford pump is significantly weaker and can damage the system.
Also be sure to use power steering fluid, not ATF!
I will also add that I had experience with hydro assist before doing this swap and is also worthwhile. The full hydro is the MUCH stronger of the two, but also allowed me to run hi-steer with low lift without having any issues with drag links or other parts hitting. It also completely got rid of all frame flex in the driver frame rail that these trucks suffer which should let it last longer, AND it steer my Dana60 much sharper. 40* full lock.
My specific kit ended up being Lock to lock is 2.25 turns, i have driven it on the road and there is no ill effects as of yet. Very responsive and very stable.
On a side note, if your truck is equiped with the steering shaft with a Rag joint on both ends, it will not work.. it cannot operate at this angle.. it binds. find an 88+ that has the U-joint on the firewall side, and a telescoping shaft and use it. bind free.
Final product:
Now, the other option you can take is using a double ended ram instead of single. The advantages to this is that you will have the same steer speed and strength in both directions. While it is not very significant, a single ended ram is slightly slower and weaker on the In-Stroke. The other advantage to double ended is that if you do not have hi-steer it will get rid of having a low tie rod to bang and bend.
All of the same above process applies when using double ended except for the mounting. The mounting is a bit more difficult. You must make a plate/mount for the ram to sit on and clamp to, then you have short tie rods that go from each ram rod to the knuckle.
The most important thing you must remember when building the mount is that the ram stay in proper alignment with the knuckles when they cycle back and forth or something like this can happen:
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Yep, we can always use more Tech info, especially Full Hydro Steering!!:icon_bounceblue:
SVT
97BlackBetty
Norman, Ok
I cant wait to buy a kingpin 60 and go full hydro (dreaming). An article on hydro assist and full hydro is always a good thing to have. I think it is a little more extreme than most of our members are looking for, but there are still quite a few of us who would like to see how others have gone about there setup.
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
Yes hydro is nice. I'm running it on my kingpin d60 with 44s and it steers nicer than my 97 with 235s.
NMB2
22
Cody, WY
5.0 V8
alright, ill start working on one. Do i submit it as a thread in here?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I'd say yeah, submit it here since we don't have a good writeup on hydro steering
SVT
NMB2
22
Cody, WY
5.0 V8
do I need to post this somewhere else or is this in the right spot?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Great writeup, is there a price difference between the single and double ram?? Also as a suggestion, if you get all straight fittings for your hoses, the 90* fittings allow for more clearance than the 90* fittings designed for the hoses...
SVT
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
Submitted.
Thanks for the info. You might see this in a future magazine issue.
NMB2
22
Cody, WY
5.0 V8
SVT
there is a little bit of a price difference between single and double. Double ended being more expensive.
NMB2
22
Cody, WY
5.0 V8
igiveup
Edmonton Ab. Canada
Hello
Great job. Awesome that you did this. I just added to your rep.
igiveup
