Full truck wiring diagram?
jonsranger
Spartanburg, SC
302
So before I get too far along on this, has anyone made a full truck wiring diagram? I've got one of the EVTMs which has most of the diagrams in it, but they are all broken up so it is easier to see individual components. I need to see the whole big picture for me to comprehend it, I am trying to clean up the engine bay and fix a few electrical issues with my V8 swap. I am drawing out the entire truck on 1 page, and I just didn't want to start from scratch if someone has already done it.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,819
Wellford, SC
3.0L
6"
I haven't heard of anyone doing that. Even if they have, chances are it's a different truck, different swap, etc. I always thought that would be cool. But I would want it to cover a good sized wall so it's big enough to be easy to read. You may want to come up with some kind of color code to make it easy to follow each system.
jonsranger
Spartanburg, SC
302
That's not a bad idea, I am already going to draw each wire in the labeled colors. My biggest thing is the like 10 connectors that arn't being used anymore, I want to get rid of those
jonsranger
Spartanburg, SC
302
Also, I am starting with just 2'x3' paper like on a large presentation pad. But I have access to SolidWorks Electrical at my work that I am eventually going to remake my diagram in that
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
Carburetor or EFI?
jonsranger
Spartanburg, SC
302
originally the truck was a 2.9l, then I swapped in a carbed 302, and recently put a roller 302 that I am putting the self contained Holley Sniper efi system on. its pretty sensitive to RFI hence why I'm trying to get rid of extra wires, plus I do want the engine bay to look nice.
RobbieD
2.9l Mafia
3,603
Georgia
Ford does have full wiring diagrams, separate from the EVTM. Here's a couple of the 1990 Ranger/B2 sections currently on eBay:
https://www.ebay.com/itm/1990-Ford-RANGER-BRONCO-II-2-Truck-Electrical-Wiring-Diagrams-Schematic-Manual/192984564300?hash=item2ceec6c24c:g:VrwAAOSw0PtdJiyb
https://www.ebay.com/itm/1990-RANGER-BRONCO-II-2-ELECTRICAL-WIRING-DIAGRAM-SCHEMATICS-SERVICE-MANUAL-90/383665880854?_trkparms=aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=20201210111314&meid=fd31efef566e4cbab8ea140514b25c05&pid=101195&rk=3&rkt=12&mehot=pf&sd=192984564300&itm=383665880854&pmt=1&noa=0&pg=2047675&algv=SimplAMLv5PairwiseWebWithDarwoV3BBEV2b&_trksid=p2047675.c101195.m1851
I have used both, the EVTM along side the Wiring Diagrams, on my '90 Bronco II and did run into discrepancies between the two. That being said, the Diagram for yours wouldn't be that expensive, and may be useful for what you're wanting to do.
Sounds like you have a nice engine swap in your truck, and I like your idea of cleaning up all of the wiring, and custom drawing the schematic for it. I think it would be worth the time and effort. Good luck!
ericbphoto
16,819
Wellford, SC
3.0L
6"
I had the big electrical diagrams book and shop manuals for my 88 F150. Those diagrams could be confusing, even for an electrician and it was not the whole thing on one page like the OP seems to want. I love the EVTM in comparison. Wish i had known about it back then.
franklin2
1,782
Virginia
Bronco II
I agree, I have the large set for my 1986 and they can be confusing and hard to follow. Even the large diagrams are on 10 + large pages. I am a electrician by trade and have worked on many different machines in factories, and I also have found the EVTM is the best diagrams to use. They are broken up into little chunks according to function, which may not be the best for what the original poster is doing, but is best for troubleshooting.
One thing positive about going over the EVTM to create a new diagram, as you study the diagrams to re-draw them it will get your mind more familiar with the wiring.
jonsranger
Spartanburg, SC
302
Ooh those look cool, are both links the same thing? Its hard to tell.
RobbieD
2.9l Mafia
3,603
Georgia
I just grabbed two links off of eBay on the quick. It looked like there were several of the 1990 Ranger wiring diagram sections to pick from on eBay, when I looked this morning.
Like others mentioned, the Ford diagrams are on several pages, but in a large format. And they can be hard to follow, with their showing everything in one view. But, for what you're planning on doing, I think that more reference material would be better than less.
Good luck!
jonsranger
Spartanburg, SC
302
Ah ok, After looking a bit deeper the $10 one was only a few pages, but the other one was a whole book. Got it ordered. Thank you for letting me know these existed. Like you said the more reference material the better.
