Gearing for best city mpg
Corie1032
Rexburg, Idaho
Hello all, I have a 1998 4x4 4.0 ranger and it has 32's on it so it is lifted a bit. I have stock gears and was wondering if i should leave them be or change them? I do more city cruising than highway and want to know what the best gearing is for city driving. Thanks!
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
City driving can use lower gears and still get good mpgs, depends on what gears you have now, what the oem tire size was, and how the truck is working now. There's no magic answer. If it feels sluggish lower gears wont hurt, if it's still taking off from a stop good and getting good mpgs leave it alone.
Corie1032
Rexburg, Idaho
Thanks for the advice, would 3.73 be low gears? It seems good on acceleration, just want to make sure its not stressing out the tranny or engine when im driving with the bigger tires.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
If you have an automatic you probably already have 3.73 or 4.10s. Those are pretty common stock gears in the autos. And you're not hurting anything with only 32" tires.
8,372
Welcome to TRS :)
Look on drivers door label to get current axle ratio, seen here: https://therangerstation.com/tech_library/axle_codes.shtml
Also get stock tire size, from same label
Then go here to see what larger tires did to ratio: https://therangerstation.com/tech_library/Gear_Tire_RatioChange.shtml
If for example your stock tires were 29" and new tires are 32" then a 3.73 ratio would now "act like" a 3.38 ratio
If you look on the Right at NEW, 4.12, that means a 4.10 rear axle would "act like" a 3.73 with 32" tires
The lower the ratio the lower the RPMs are at the same speed
But the lower the torque applied is as well
Higher ratio is better for towing or stop and go driving because it applies torque better at lower RPMs, for city driving
Larger tires have a triple whammy effect on MPG in city driving because they are heavier, they raise vehicle higher and they lower the axle ratio
On the highway the lower axle ratio is better(lower RPMs at 70mph), but heavier tires and high stance lowers MPG
