GEM module swap
horsappl
Dalton, MN
I have a defective GEM module and gauge cluster in a 1997 Ranger 4.0 with manual transmission. I have a junk 2003 Ranger 4.0 with automatic and good GEM and gauge cluster. If I try the 2003 GEM and cluster in the 1997, could it damage something?
Has this been done successfully? I have swapped GEM and gauge clusters on F150's, but I have always found a matching part number on ebay, but now I have a junk pickup to steal parts from. I used the coil pack from the 2003 on the 1997, and it worked fine.
horsappl
Dalton, MN
I took the GEM modules out and the connectors are different, so this won't work.
8,370
Cluster will swap, 1996-2003 have same wiring and size/shape
GEM will not, as you have found, 1996/7 GEM should be OK, from vehicle with matching "options"
Try: https://www.car-part.com/
For Part select "Computer Box not engine"
And use your Zipcode
Search
Next screen will ask what box you need
"multifunction" is the type of box, and should have matching Ford ID number, select it(last 2 digits are important)
Search
It should give you local available parts and years that will work
Mazda B-series used the same GEMs
Engine size or transmission type didn't matter for GEM, it just controls cab electrics
Yes, "Multi-function switch" is also what the turn signal unit is called on Fords, in this application that is not what it means, lol
horsappl
Dalton, MN
Thank you!
I ordered the GEM and intend to use the 2003 gauge cluster.
