Gen1 Gen2 Door Interchange Guide
Darksyne
Perryville, MD
I swapped the dented and beat up driver-side door on the Gen1 this weekend and thought I would detail the differences I found for anyone doing this in the future.
The exterior of the door is the same and bolts to the hinges in the same way.
The differences are primarily the trim mounting holes on the inside of the door. I'll compare the differences I found below.
Armrest:
Gen1: Armrest mounts with three plastic clips that fit into square holes on the inner door frame. The Gen2 door has these square holes, so no problem using a Gen2 door with a Gen1 armrest there.
Gen2: Armrest mounts on a bracket that is affixed to the door with two screws. On my 88 door, the location of these holes were marked with an X but were not drilled. You'll need to drill these two holes to mount the Gen2 armrest on a Gen1 door.
Door Panel:
Gen1: Door panel mounts to the door with an excessive number of Christmas Tree clips. All of the holes are present on the Gen2 door. However, the Gen1 door panel does not cover the painted area at the top of the door and uses a separate inside window felt molding with clips that secure the molding into holes in the inside top of the door on the window-side. The Gen2 door does not have the holes to attach the inside window felt molding. You can fit the molding fine but it will pull out whenever you put up the window. Glue may be an option.
Gen2: Door panel mounts with an excessive number of Christmas Tree clips. It will mount up fine on the Gen1 door after you remove the inside window felt molding.
Manual Window Crank:
Gen1: The splined shaft that the window crank attaches to is slightly longer on Gen2 doors. There will be a half-inch gap when you install your Gen1 window crank on the Gen2 door. You may* be able to use the Gen2 window crank to resolve this minor cosmetic problem.
Gen2: The splined shaft that the window crank attaches to is shorter on Gen1 doors. I didn't test a Gen2 crank on the Gen1 shorter shaft so it may* work fine. My concern is that the crank would rub excessively against the door panel since the crank won't seat fully against the end of the shaft.
These were all of the differences I encountered while replacing a 88' manual window, manual lock door with a 91' manual window, manual lock door. There may be additional electrical work not mentioned here when swapping doors with power accessories.
If anyone posts information related to specific electrical issues when swapping doors between the generations I'll update this post with that information.
*= not tested so YMMV.
Seabiscuit
Phoenix, AZ
Please define generation 1 and generation 2
Southern3.0
New Port Nowhere FL
'96
2.3, what a turd...
gen 1 83 - 88
gen 2 89 - 92
When I had my '91 I always wanted to swap a set of gen 1 doors on because of the fly windows
Bill G
4
A $20 fuel surcharge from Tucson
1984
2.3, 2.8
I still want to swap mine. I like the wing windows better but haven't been able to find any locally at a good price.
Branger
Syracuse NY
Ford ranger
393
4/6 on air
315/35r17
I have a 91ranger . will 91expo doors bolt up?
id like to have those due to the location of the mirror. I have 87 doors on now and the mirrors are set back further than the original 91 door. But my doors are tweaked so I’d like to replace them before paint
any Info will be very much appreciated, thank you
I believe the doors fit the hole and bolt up, but the shadow lines are wrong.
