- Aug 15, 2019
- 1,988
- Oklahoma
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
About got the hoist rig figured out best I could, but still need to check it along the way. The lift chain I got first is serious overkill but it will work ok. I took a hook off the come along and put the chain link right into its place.
Took the hook off the top also and rigged a grade 8 bolt through it all to allow two full loops on top. It was very tricky putting that puzzle together but it came together in a way all links are equally absorbing the weight. Figuring 500 pounds that's 125 on each end, with the 4 ends creating 2 full loops, leaving one as a backup if anything did go wrong with the other.
After getting that puzzle together I wasn't going to take it apart before I'm done with it, so I took the come along apart to take it down. I have seen the inside of one of these swivels before but it was likely on one that had busted, I have a bit more confidence in this one when it's put back together
