Got stalled bronco started in some starter fluid…question
Casiokorg
Usa
Bronco II 2.9
Was able to get her running for about 40 seconds vis some starter fluid spray. Does this pretty much confirm it’s a fuel / fuel pump issue? Also the ticking sound is new?
8,374
Yes, if you have a "crank but no start" and adding fuel manually(50/50 test), gets it to start then spark is OK, its a fuel delivery issue
ticking noise can be loose spark plug wire(arcing) or lifter, lifter "tick" is most common on 2.9l
