Grinding, scraping sound
four100d
Ohio
Stock
Stock
I recently replaced the Auto hubs on my 95 4.0 4x4 with some used manual hubs I got from pick and pull because I thought the driver side auto hub was bad and it was making a grinding, scraping sound. (hard to explain the exact sound)
But after I installed the manual hubs the noise is still there.
I opened the door while I was driving (slow) and it's kind of hard to tell where it is coming from. It definitely sounds like it's coming from the driver side, so I guess it could be coming from the transfer case, the u-joints, or even the differential, I can't really tell for sure.
Basically whether the hubs are locked or not the sound is there until I disengage the 4x4, then it stops. So if the sound is still there with hubs locked or unlocked, then that would rule the hubs out, right?
I am going to check the fluid in the transfer case and front diff later tonight or tomorrow. Anyone have any ideas as to what it could be?
broughton88
Hudson WI
My 93 kinda does that two and it was auto now man lockouts but then again I have a loose ball joint and mabe a wheel bearing
four100d
Ohio
Stock
Stock
Man, don't I feel like a dumb**a! It was late last night when I got done installing the manual hubs so I didn't spend too much time trouble shooting.
I just now went outside and was going to check the fluid in the t-case and I found the problem.
The person who owned the truck before me ran a new brake line to the rear, and that brake line had somehow shifted away from the frame and was rubbing the drive shaft coming out of the transfer case! Here I was thinking the worst... :)
I guess the brake line did help me talk my wife in to getting some new (to me) hubs. I actually went there to buy just a replacement auto hub and told my wife I was only going to spend $35. Well, I found some manual hubs on an explorer and I decided to do the swap, they cost $68 and some change. I like the manual hubs a lot better.
I just took the truck for a drive and everything seems to be working like it should.
Thanks for the reply!
Well the moral of this story is, check out your sh** before you ask for help... :icon_idea:
broughton88
Hudson WI
Haha nice and simple fix
