Steering with a singularity, now that would be an interesting feat.
it would
wheres stephen hawking when you need him.
anyway,i was left with two choices,since mr hawking isn't chiming in...
this is the bmw rack.power steering is nice,but it's bulky and i don't think i have room for a pump anyway.
this is the original gt6 rack....no power,but much slimmer.i think this is as close to one dimention as i'm going to get.
the next problem is that i cant put it above the frame,the engine is in the way.i cant put it under the frame,it goes against the rules....and would drag on the ground.
the plan is to cut a 2'' hole through the frame rail and sleeve it with a piece of tube-the tie rod can pass through it.
the wire is in line with where the tie rod needs to go,so the hole will be drilled directly under it.
this photo is taken from the left front looking toward the right side frame rail under the motor....this is how much room i have for the rack.
