Guys i can save this if..
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
i can get 975 bucks.
http://bemidji.craigslist.org/cto/2562350129.html
I have a 1983 Ford Ranger Regular cab, short box. It has a 5.0L,302, 4 barrel Edelbrock, with a c-4 trans. It has possi, a fuel cell in rear, and the battery is in the rear. It also has a hood scoop, sun viser, razor back, and a openable sun roof. Very fast and LOTS of power. Asking $975.00
Il Brutto
02/2011 STOTM Winner
MTOTM Winner
8
Huntingdon, Pa
If it ain't broke...fix it before it does.
You must be a superhero.
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
It's gonna take more than $975 to save that...
It's in need of a new hood, wheels without hubcaps and someone willing to remove that racerback at the very least...
3,614
Son, their ain't no saving that.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
It looks like he was setting it up for time travel. Must have run out of money........
nine-teen91stxranger
30
clearwater, minnesota
Ford, Ford
245 cid of fury, 6.6l
shane, it matchs your fox... with stretching your immagination...... alot
superds
80
ND
Ford Bronco II
You guys treat it like it's an S10 or something...
3,614
TheTopher
176
Delaware
2.3
+1
I believe you got yerself enough money pits.
You already own a jeep, after all. :icon_rofl:
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
just go steal it and take it to the scrapper. the truck is miserable, i can see it in it's headlights
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Well, that second one you posted might work, but the first one you posted clearly states:
"Flux Capacitor requires the stainless steel body of the 81-83 DeLorean DMC-12, V6 2.9L , to properly function."
That's kind of a disheartening fact to learn after you have put so much time and effort into a vehicle. I'd be selling it too if I were in this guys shoes. Maybe someone should contact him about the second unit you found?
:D
racsan
4,521
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
flip that hood scoop around and it will have some serious forced air induction. lol
