Has anyone done the coilover conversion?
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Was debating starting a new thread. I did it. Can't undid it.
So has anyone still around the forums done the coilover conversion on a 1998+? Pros? Cons? Better than torsion bar? Things you'd do differently?
Edit: extremely good thread on the subject:
Blmpkn
Toilet enthusiast
6,379
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Pros... coilovers.
Cons... labor.
Better than Bars? Absolutely.
First hand experience.. none.
superj
2,690
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i looked for one of the kits for a while because i wanted to do it on the 04 edge i have but i couldn't find one of hte kits so i gave up. i would much rather have coils on the front.
if you do it, list where you go the parts and part numbers so when my ranger comes back, i can do it too
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Yeah, I'll throw a thread together. The only brackets I can still find are the northpeak ones
I talked to him last week, he still makes them.
The coilovers are the next ones. I need to see what's still available.
superj
2,690
ranger edge
none
none
235s
thats the part that was killing me was the brackets. i couldn't find anything but old posts about them in different forums and no one appeared to still be making them.
ericbphoto
Overlander in development
16,732
Wellford, SC
6"
Unfortunately, some of the best aftermarket parts are only made by
And
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I can.
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
5.0L GT40
I have coilovers on my lowered awd Level II, I just made the upper brackets from a piece of box tube, there isn't much to them at all. And for the lowers just a regular shock mount is needed, just weld it to the lower arm.
The mounts they sell are nice to be able to bolt-on but come at a very high cost, if anyone has a friend that can do the most basic of welding these can built for pennies. And if you do the gussets on the frame as well someone's got to be welding those on anyway.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Awesome setup.
I wound up ordering a set of the North Peak ones from Matt. Nice guy, lurks here from what I can tell. https://www.northpeak4x4.com/
I'm guessing you made the sway bar link mounts as well? Way nicer setup than stock. I may copy that...
Just out of curiosity, which shocks and springs did you go with?
Blmpkn
Toilet enthusiast
6,379
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Did you plate or otherwise reinforce the lower arm for the shock mount? Those arms arent exactly the thickest steel, I'd be worried about it getting stressed over time and cracking/breaking. Lots more pressure on that arm supporting the whole vehicle.. rather than just damping.
JoshT
1,816
Macon/Fort Valley, GA
So what is it that you think the torsion bar connects to? That arm has supported the whole vehicle from the day it rolled off the assembly line.
sgtsandman
Aircraft Fuel Tank Diver
12,764
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I can see where he is going with his question. The pressure point has moved from the hex eye in the control arm and is concentrated there. With the coil over, the pressure point is moved further down the control arm.
Granted, shock damping forces were taken up by that area already. So it might not even be a problem but with that section now not only taking the damping forces but also supporting the vehicle, it is a valid question to ask in my mind. The type of forces enacted in that area have changed.
lil_Blue_Ford
6,221
Butler, PA, USSA
4.9L
That’s pretty much my thoughts too. You’re changing the dynamics of it, the area around the torsion bar is reinforced so I’d think reinforcing around a coil over mount makes sense.
JoshT
1,816
IIRC, you've also got the bumpstop making contact in that area. When bottoming out the bumpstop is going to be taking the full weight then some, so that area of the control arm is also going to be supporting that much force. That area of the control arm has to be designed to take it.
Not saying that I wouldn't rather have the reinforcement provided by the adapters that have been sold. I just don't think that not having it is a problem.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Probably a useful update... talked to Downsouth Motorsports today, and they sent me the attached quote based on my setup.
Not horrible... not cheap, either. However I did spring for reservoir shocks vs emulsion, and they are making valving adjustments to the shock bodies for my needs (90% pavement and 10% Pennsylvania rural roads). Should put me 1-2 in over pre-lowered keys stock height, which is exactly where I want to be.
