Has anyone dropped a Ford 300 into a first gen (1983-1989) Ranger?
MadMax_636
47
Georgia
2.8 V6
2.8L
However much it goes up when I get my fat ass out.
How much it goes down when my fat ass gets in.
Dry rot and old
Im thinking about getting a Ford 300 that comes with a 5 speed so I could use the trans for my 302 but I was thinking that maybe if I could fit the 300 in my ranger. Id use that. Mainly since they are bulletproof motors, 4.9l in size, and have better power ranges than a stock crown vic 302.
I also wanna do it as a proof of concept and itd just be super fun and cool to do everything.
NOTE: Im already planning on putting a 3-4 inch body lift for the 302 so that would probably also help with fitting and pushing the 300 deeper into the firewall. Im also planning on replacing the whole floor of my truck and doing custom work to it.
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
They will tell you not to, but do it. Not because it's good idea, but because it's a great Idea.
Junk Collector
Truck of Month
4,860
Rapid City SD
This topic has been beaten to death...search around a little bit.
That said. Have you driven a truck with a stock 300 before? I have owned several. They are great engines and I love inline sixes... but they were also the base option, no frills, cheap truck engine. They pull hard at low RPM but run out of steam really fast. And as far as longevity goes... there are many 5.8s from the 80s and 90s still running around and it's not uncommon to see them with 300k+ miles. Personally I think the 5.8s in the 90's were the high point of Ford reliability.
superj
2,711
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i say do it also. and than put an offenhauser intake on it with a small four barrel and a header and it ought to fly
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
That was sorta the plan. It wont be stock for sure. I aint running a single barrel.
Either a 2 or 4 barrel, dual exhaust, and a stronger top end.
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
My vote is for EFI carb conversion.
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
I would if I knew anything about EFI. I dont wanna have to deal with setting up the extra gizmos for efi.
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
They sell more or less self contained kits that teach based on the feedback from the 02 sensors. Holly sniper is the big one, Fi tech is anouther big one, it looks msd also makes one.
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
Here is an article that has some info on them. The only downside I’ve seen about this type of thing is the upfront cost.
pjtoledo
3,005
Toledo Ohio
Fords
3.0 2.3
Powernation/Engine Power built one recently. when they were finished with it they had plenty of steam.
Ford 300 Turbo : Engine Power (powernationtv.com)
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Power aside... if you plan on keeping the nose OEM, then we are talking firewall moods, extensive mods.
What is your idea on making room for the extra length ?
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Perhaps a tape measure would help with the decision. I loved my 300 in my 70 f250 but that’s a loooong block for a BII or Ranger. OEM front end would put the bell housing between the seats. 🤣. Split the dash and tub the hump.
If you do it we would love some pictures. It would be epic.
fastpakr
2,848
Roanoke, VA
It's been done, but i can't remember anyone doing it without major firewall surgery. If you want something unusual, go for it. But there are far more reasonable options for increased power.
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
lifting the body 3-4 inches, cutting the firewall and floor to make room. I already need to replace a lot of the floor in my truck. My cab is rusty but I wanna learn how to fix anything and everything thats wrong with it.
MadMax_636
47
Georgia
2.8 V6
2.8L
Dry rot and old
yeah, I know I already have a 302 sitting in my garage that just need all of its gaskets replaced with modern ones. (its from a 84 LTD) and the 4.9 trans will bolt right up. I just started thinking about putting a 4.9 into my truck as a crazy and different idea.
