ghunt81
- Apr 7, 2015
- 0
- Clarksburg, WV
- Ford
- Engine Size
- 4.0
Whenever I tried to fill my truck, the gas would constantly back up into the neck and click off the pump, unless I actually held the nozzle completely out of the filler neck and trickled in gas. It would take 15 minutes just to get 10 gallons of gas in the thing.
I asked about it and got a lot of "Well, that's just how Rangers are," which I did not think was an acceptable answer. It seemed to me like a fuel venting issue.
Years ago I did a mod the filler neck on my old F250. They are notorious for this sort of problem because of how foamy diesel gets when it comes out of the pump, and they also used that old hose-in-a-hose style of filler neck. It pretty much involved gutting the filler neck and rollover valve, putting a new fitting in the rollover valve and in the filler neck and running a 5/8" hose as a vent.
I don't have any pictures but over the weekend I wanted to see what I could do with mine. I pulled the bed back and took off the filler neck and vent tube. It looks like the ID of the fitting at the tank where the tube attaches is only 1/8" which is pretty small for a vent.
I found an old vacuum tube with push lock fittings on the end from my Mustang that was laying around, and the push lock fittings just so happened to fit the plastic nipple on top of the tank perfectly. So, I cut the hard plastic line off the fitting so I had just the fitting, and it fit a 3/8" rubber tube pretty well. I also cut off the original vent tube from the filler neck, drilled out the hole, and put in a 1/4" npt elbow (JB Welded in place) and a nipple for the hose. So, I now have a larger vent tube running to the filler neck.
I got gas today at a station I could barely use the pumps at before, it still isn't great, working better than it was but I can still tell it's not venting as well as it should be. I'm now wondering if enlarging the two little slits at the top of the filler neck might help since that's the only place the air can vent from and it's also very small.
Has anyone else tried anything like this, what did you do? Sorry for the wall of text.
