Be patient with me if i seem out of touch....
why not duraspark it and run a manuel choke holly 350 cfm carb? I got all my stuff for maybe $150 total it took maybe 2 hrs to set up and adjust and never had any problems. I ran the truck in weather as cold as -10 F. Set up the timing to 15-12 deg dtdc and let it RIP!!!!
Sounds like what you've got going is working for you..and it's all good..
I'm probably a little ancient geneologically compared to the average age posting here but ..we DO have car stuff in common..
As an owner of a 2.8L that happens to power a BII 4wd, i find myself in one of 3 different groups that post here I think maybe..
A
2WD group who drives a PU maybe even a low-rider that maybe power but yet some economy may play a part of our tuning goals...
A
4WD group with Bigger tires and lower gears to venture over rocks and ford the rivers..
And those who just want a "running dependable cheap veh that "uncle Bill" handed down for them to "fix-up" for
transportation whether 2wd or 4wd
One thing I think we all have in common is a good little motor with a few freckles that given it's age now and it's "last known" method of fueling/ignition is experiencling challenges to stay drivable and tunable as parts deteriorate etc.
Before this 2.8L/2.6L became puter controlled it was carbuerated by a Holley/Weber 5200 variant in a 1974 Mercury Capri, Mustang II with a set points in a distributor. Hardley a 350CFM carb although it can be turned infinatley for up to about 240CFM I am told.
Trying to run this 2.8L w/o a puter and all of it's smog controls seems to lower fuel mileage greatly..
I'm on a quest to have mine running at peak efficiency not being "over-fueled" as they say..call it a challenge but i guess maybe it's my own interest in what makes a motor run and run well is what is taking me there..
Of course you can put a cam in any motor..and build it for more compression and more air flow and then use more fuel..but I don't think this 2.8L with stock cam needs more than about 190 CFM or so for my use ...
It seems that for the most part we have chosen to put a band-aid on this motor by "durasparking" it..w/o looking at a more efficient fuel source..there again probably not important to someone who just wants to "make it across the pond or mud bog..(not saying that's not important).
I just like the concept of an efficient A/F ratio in a gasoline powered veh..isn't that what fuel injections does for us?...it supposedly maintains that A/F ratio...well, the carb/spark curve/air flow tuning is what makes a carbed engine run..and tuning for excellence is what makes it more perfect. The difference with a carb is the driver does the tuning not the computer..
The good news is..no matter how crummy or far off the A/F ratio is..a carbed/sparked rig generally starts, runs from gas pump to gas pump..with little or no aggravation other than spark plug changes..and a few hicupps and belches now and then...and some black smoke occasionally.
So..on with tuning..no matter what carb combo you have..
I like the idea of owning a carbed motor again...and I also drive a high MPG 2.9L which I like as well..but I do like the idea of being able to get around with the simplicity of a few hot wires and some gasoline..or with
larger jets..in my old-school carburetor...even
grain alcohol if need be as Henry Ford designed his 4 banger to run on.....
