koa's93ranger
- Jan 12, 2009
- 2
- Las Vegas
- Ford
- Engine Size
- 4.0L V6
I'm trying to replace my transmission today. Got everything unbolted and harness un clipped. Ready to by dropped down. I ran into a major issue removing the clutch line. Apparenly I'm missing the plastic collar that goes into the slave cylinder coupling. I tried everything to release that lock and remove the line and I'm out of options. Called ford dealer and they told me I had to cut the line and replace both the slave cylinder and the clutch line. That's a load of bs. The same dealership replaced my clutch last year and they were able to remove it without that plastic collar. So it is possible. Is there anyone that has done this before and could give me a tip on how to remove this without replacing the clutch line and slave?
Thank you
Thank you
