Hazard lights not working correctly
bryanb
Western Montana
2.3
1989 Ranger.
Hazard lights work oddly. use replaced both flasher switches in the fuse panel. Makes no difference in problem.
Hitting the hazard button, and they work fine, but if I apply the brake pedal, they stop, and are only on solid (not blinking) like a brake light.
Is that normal, or something wrong?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,569
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If the stop and turn signals share the same bulb filament... it's normal.
holyford86
Some guy with a problem
638
Plattsburgh, NY
many
33x12.50R15
Can confirm, you are describing normal operation, there is nothing wrong
4x4prepper
216
Atlanta
