Head gasket instulation
Scolof
Rochester,Michigan
Im rebuilding my 84 bronco 2 and was wondering if anyone had any advice on weather i should use permatex copper spray-a-gasket hi temp sealant on my head gasket. Some people say you should and others say you dont have to. Any info helps thanks.
8,370
Check the block surface for flatness, use a straight edge with a flash light behind it to check if block is flat, minimal light passes under straight edge
I assume the heads have been cleaned and surfaced?
or do the same with heads
If block and heads are flat then nothing is needed except the composite gasket.
The head gaskets metal rings for each cylinder hold back 900+ PSI when a cylinder fires, they are the important part, and RTV or copper spray does nothing for them.
The water jacket holes have 12 - 18 PSI(Rad Cap rating) so not much pressure there
If their are oil passages, not the drains, then they are maybe 40-50psi, which is alot but block or head would need a deformity to leak at those 1 or 2 passages.
So no treatment is needed, IMO
MLS(multi-layered-steel) head gaskets can use a spray on sealer, they are only used with aluminum heads through, they tend to leak when Cold
It is not NEEDED. I like to do it because it helps hold the gasket in place during head installation. I know that's what the dowels are for, but it won't hurt anything and it does hold the other corners down.
No members online now.
