header issues
greenstranger89
hi im getting toward the end of my swap and im having major issues finding headers that work i got a set of headmans that were supposed to be for this swap but they didnt clear the steering shaft or the passenger side frame rail then i tried a set of explorer manifolds which cleared everything but the spark plug wires and boots because the plugs are on a different angle than an explorer so does anyone know if they make either a set of shorties or long tubes that will work and clear all the problem areas thanks jim....
WWard
Puyallup, WA.
302 V-8
Tri-Y's maybe?
I'm using a set of Patriots that I got from Summit...they worked fine for me...with only a slight trimming on the passenger frame rail.
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
What year is your truck, what engine and heads are you using, what mounts are you using, 2wd/4wd... manual, auto, which specific trans...
greenstranger89
its a 1989 xlt ranger 2wd im using the andvanced adapter plates with convertible mounts and a t5 tranmision and they are stock 1984 mustang heads.
Lil John SVT
Tri-Y's maybe?
Do you have a part number for the patriot headers?
greenstranger89
do those patriots fit well id rather not order another set and them not fit . but thanks for all the help so far.:icon_thumby:
WWard
Puyallup, WA.
302 V-8
I'll try to get some pics of mine up here tomorrow.
I think they fit fine....for me...in my '85...I dunno how much of a difference there is in an '89, probably not too much.
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
Yes, Tri-Ys typically fit very well in a 2wd manual trans Ranger. Mine fit perfect, and clear everything. The application is '65-'70 Mustang, generally called "Shelby Tri-Y"
Couple of shots of the headers.
greenstranger89
Thanks for all the pictures does anyone have a good shot from the driverside from the top just to see steering shaft clearances bc im gunna order a set of the patriots todY
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
Some old shots:
They are nice and high, too- above the frame rails.
WWard
Puyallup, WA.
302 V-8
Here's a few shots of mine...
keeno
Griffin, GA
2.3
Thats a notch cut out of the frame on the pass side??
Lil John SVT
I have a set of tri y's also. Haven't put them on yet though. I hope they work with my c4 trans.
