headlight chime
RPD
maryland
I suppose this is supposed to go here, but correct me if im wrong. so I recently picked up my ranger, its pretty decent, but the problem I'm here for is that the headlight warning chime will sound whenever I open the drivers door, even when the lights are off. it turns off when the truck is on, but just keeps dinging at me if I just open the door. any thoughts?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,552
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That sounds more like the "key in ignition" then the light switch warning.
I know my 06 will sound the light on alarm with door closed and just by turning the ignition off.
RPD
maryland
oh wait, I meant to add this, the headlights are not on when that happens. im sorry about that
Uncle Gump
Token Old Guy
13,552
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I kinda assumed that the lights were off when this happens.
Try this... all doors closed... ignition on... turn the park lights on. Now turn ignition off... light chime should sound off. This is the way my 06 works.
If the chime doesn't sound off until a door is open... I think it's a key in ignition warning.
RPD
maryland
ok, thank you so much!
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Diff year and gen but here goes. On my '97 I had this exact same issue - key is out, but opening the door you got 'key in ignition' (but not if key was 'on'). On mine, if you take off the clamshells on the steering you can see the little contact, in this case it wasn't secure in its position and could make contact where it wasn't supposed to. I took a small strip of tape and wrapped around there to hold it, problem solved, it works properly. Admittedly that's a tape job not a "real fix" but it solved it, and, if it comes back, which it hasn't, I'd know right where to look. Not sure what the "real fix" is but it looked like it might involve replacing the ignition cylinder which I'd rather stay away from if possible.
Anyway if yours is at all like mine and you take off the clamshells you should see the contact for this function and probably it's floating around in there. Then you can move it around and probably make the chime go off and that tells you where it's supposed to be, and secure it there somehow.
Maybe could be other causes too but I thought I'd throw that out there as it sounded real familiar.
  • Like
Reactions: RPD
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
Adding, it happened after I had my truck in my "good shop" and I was like, man, even my good shop is breaking things. Then I remembered the guy told me "I had to move the steering up because I couldn't get in" (I always keep mine all the way down). So probably the thing was always loose and it just got moved around. I still think the shop is good but just and example how you can get truck back with more than was wrong with it to begin with. I didn't notice it until I got home because he backed the truck out of the shop and it was running so it wasn't chiming. Then I got home and was like wtf. You should be able to fix it, hopefully for free (less a little of your time).
  • Like
Reactions: RPD
RPD
maryland
ok, thanks, that sounds like its probably it
RPD
maryland
ok! awesome, thank you for letting me know
