ekrampitzjr
- May 28, 2021
- 1,099
- Virginia
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
Sounds as though the engine overheated. You should look at replacing the radiator, because the existing one is probably clogged.Hi, I just bought those corners today for 45 $ each. Just waiting for transport to Poland.
This is 3.0 Vulcan Engine , its under construction now Heads are cracked , pistons and rings needs to be replaced, and cylinders remachined. I hope it will be worked. Bottom end is in mint condition.
Is this any rewiring diagrams for tail lamps to EU conversion? Or should I buy trailer converter to separate turn and brake wires?
A trailer converter might be the best solution for the rear lamps. By the late 1990s I believe some of the lighting functions were controlled with electronic modules, and changing those would be a problem.
Keep us up to date! We're looking forward to seeing your progress!
