help fast
Deamers87ford
Lancaster, Pa
hey guys so my trucks been pushing all my coolent out the over flow tank. i have replaced t stat, water pump, head gaskets. could it be the radiator?
please help i need a car to drive again
modelageek
14
Boston, MA
did you replace the radiator cap?
Deamers87ford
Lancaster, Pa
yea got that 2 also the radiator was sittin in garage for a while
miniloaf38
2.8 Duraspark II
It's a 2.9, were your heads cracked? Did you inspect them when you did the gaskets?
Duane867
9
Columbus
2.3L
Pressure building in the over flow that not heat related ( IE hot coolant ) can only mean one thing. Bad head gasket or cracked heads.
Seeing as you truck is a 90' though I'm going with bad or incorrectly installed head gaskets or intake gasket.
Deamers87ford
Lancaster, Pa
turns out i screwed up installing the t stat
the lil air thing has to be up and i messed it up
Duane867
9
Columbus
2.3L
Douuuuuuu !!
