Help me understand doubler ratios
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Thinking of putting an Atlas 4 in my truck, but I might try my hand at building a doubler since I have most of the stuff laying around and I have the skills (and access to people with more skills than me) to get it done. So I am assuming you can shift the main transfer case and get 2.48:1. Then you can shift the planetary in gear I am guessing. How do you calculate the final ratio from there? 2.48+2.48 or is it 2.48*2.48? School me please.
Roert42
4,996
Kintersville, PA
Ranger XLT
4.0 SOHC
Trans gear ratio x transfer case gear ratio x doubler gear ratio x differential gear ratio
Roert42
4,996
Kintersville, PA
Ranger XLT
4.0 SOHC
Every set of additional gears you add you are multiplying the last set of gears by the next one.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
