- Aug 31, 2021
- 974
- Roanoke VA
- 1997 and 1999
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
Well, even with the correct tool to hold the crankshaft pulley, the crankshaft bolt still won't come out. He's putting a lot of force on it.
He is putting car back together and says he is going to take it to a lift (this was mentioned earlier) so he can get under it and get a better angle on it.
Any ideas on getting that bolt out?
In my experience you can have a couple things happen if you keep messing with stuck bolts, either the head breaks off or the hexagonal head gets so messed up a wrench won't grab it.
Either of which would be basically disastrous. Torque is supposed to be 300 ft lbs but it's stuck in there some multiple of that.
His electric impact wrench wouldn't touch it. So maybe big air wrench could break it loose.
It's a mess, you can't change timing belt (let alone water pump) without getting that bolt out.
