- Aug 31, 2021
- 974
- Roanoke VA
- 1997 and 1999
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
Yes, I didn't price it specifically from Lexus/Toyota but I suspect it would be all of what you said.
So 250 for parts plus 650 (estimate) labor plus 100 to haul it there, that's -maybe- 200 cheaper than name brand shop, not a ton of savings really but at this point the idea I was going to save a lot (250 labor, originally) seems like it's out the window.
I probably should consider it lucky to even find (fastpakr find actually) a shop that will take a half-done job and take the parts.
Don't forget the timing belt is slipped a couple notches, so car will run, badly, but I wouldn't want to drive it across town like that. CEL is on and blinking, no doubt it detected that timing is screwed. So it's not even 'the same' as it was, it's way worse.
Other half says "put it back the way it was and send the parts back and I'll drive it until it fails". Is this an option, I suppose, my guy says he can get the timing belt back where it was for no charge, but that means taking it all apart again, maybe not getting it right (seems like you can, though). Anyway, I don't see "drive until it fails" as a good/sensible option.
I told my guy, if we can't make anything happen by Monday, I'm going to haul it to another shop. It'll be a week by then it's been sitting, unusable. Then I'd take the hit myself on the basically 500 difference (400 add'l labor, plus the hauling, and that's assuming something else isn't screwed up) and in theory the car is then usable and fixed, and other half isn't out any more than the original deal. I guess I see it as my fault to assume since my guy had done other jobs fine, he said he could do it, I believed it, and I was wrong. And it kind of sucks because although this is probably an exceptional thing, it makes me question doing further work with him, I guess you call that loss of confidence.
This has gone so far past what it started out to be it's not funny. And the above isn't even including giving the guy something. He's out a bunch of time and bought some tools. I guess this is what happens when you say "I can do it" and then find out oops, I can't do it.
Edit: He says he can't do it (gave up). He says I don't need to pay him anything because he didn't do the job. So I'm going to get it hauled to the other shop. Let's hope a) they can do it and b) nothing else has been screwed up.
Argh.
Argh.
