Elijah1989
- Nov 29, 2016
- Reaction score
- 3
- Location
- Roopville, Ga.
- Make / Model
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9L
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 4 inch body
- Tire Size
- 265/75 R16
- My credo
- Eagles May soar, but weasels don't get sucked into jet engines!
Based on the picture below I need to replace this item. It is no longer attached to the Valve cover. What is it called and do I need to remove the Valve cover to replace it? I checked under the hood after driving it around for fun today and noticed it was sitting cattiewompus in the hole it’s meant to be in. I know it has to do with the vacuum system. And it might explain moisture in the oil since it is an open hole into the engine.
Any help would be appreciated!
