fireguy12117
- Aug 9, 2007
- 3
- Age
- 44
- Livonia, Michigan
i need some help with witch way to go on verifying a coolant leak issue.
so far i have white exhaust and a coolant level that dropped over a period of a couple months light city driving. no matter how long of a trip i take, the exhaust stinks and stays white.
today is when i discovered the low coolant level, so i wasn't sure what to next but tried my best at a compression check. i got 110-130psi on 5 out of 6 cylinders with a POS harbor freight thing. i couldn't get the rear pass side cylinder 'cuz the air box makes it too tight. also, i couldn't tell a difference on any plug to indicate being fouled by coolant. they all looked pretty good and identical.
i was imagining that if i had good compression on the cylinders that maybe it was an intake gasket leaking into the cylinder.
the T-stat operates like it should, opens after some driving. the temp gauge fluctuates some...so...my next step is to try what was suggested in another thread on running the truck and looking for bubbles in the rad fill cap. in my experience i've always had a geyser eruption when i did this, but we'll see.
im in a pinch. i was supposed to take this money pit up north in 3 days, now i dont know what the heck ima do since there is a good change i need 4wd where we are going but cant risk blowing a head gasket in the middle of BFE.
