Help with shift question??
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
2004 ranger . Question is when I put it in 4 low and drive on the collum should it try to upshiht to 2nd gear and then drop back to first gear . This is driving me up the wall because I'm afraid I might need an overhaul. Thanks
8,374
When in "Drive" the computer will control the transmissions gear shifting/selection.
It uses RPM, wheel speed(speedometer) and throttle position, to determine the best gear ratio to use.
I have never owned an automatic 4x4 so can't say how it would shift when in 4low.
I would think you would what to use manual shifting, i.e. select 1st on column or 2nd to maintain driver control of shifts.
But just guessing
Dangerrangers
Ohio
94 and 04
4.0 s
But just guessing
I'm thinking your 100% right on putting it in drive 1 to control the shift , but if I remember correctly it always stayed in low gear ( drive 1 ) ever when it was in regular ( drive D ) . Maybe I'm just getting to darn old and can't recall this correctly . It goes into 4low just fine and all else seems OK . Thanks Ron , you need to get an automahtic , no really I wish the 04 was a stick .Thanks again !!!!!!!!!
pjtoledo
3,003
Toledo Ohio
Fords
3.0 2.3
my 2000 4x4 ATX will shift thru the gears in 4 low. tops out at about 45mph.
8,374
I like automatics, all my cars are automatics, just seems like all the 4x4 trucks I ever owned were manuals :)
My CTS has a SNOW setting for auto, it doesn't use 1st gear, you start off in 2nd which makes sense don't want that torque to start tires spinning.
Dangerrangers
Ohio
94 and 04
4.0 s
Caddy , now that's a nice set of wheels , I grew up with caddys ,my father was a GM exec and we always had GM's but I broke the mold when I bought my first Ford at 14 ,it was a 57 starliner , man I almost became the only son to get booted out of the house ,just kidding.
Dangerrangers
Ohio
94 and 04
4.0 s
I'm going to try that in the morning , I hope it's either raining or snowing in the morning. Thanks
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
I s'pose testing 4 low is good , but the torque is what you don't need in snow. If you have AWD , put in 4 High and D to keep wheel spin to a minimum. :D
I think I could hide my own Easter eggs, this year.
Dangerrangers
Ohio
94 and 04
4.0 s
You didn't read or understand the first post!
modelageek
14
Boston, MA
As Ron said just put it in Drive and go. I however would not use 4 low. It's only if your stuck. I shift into 4 low twice a year just to keep it working. I shift right back out of it.
"Losers focus on winners, winners focus on winning" TB12
Dangerrangers
Ohio
94 and 04
4.0 s
That's all I was doing is testing it ,I'm not stupid ! I never had it shift up when it was in 4low and was just asking if it was suppose to up shift when in 4low because I don't recall it upshifting when I was off-road and going much faster than the other day when it shifted to 2nd and then abruptly dropped down to first gear . I hope you understand now.
pjtoledo
3,003
Toledo Ohio
Fords
3.0 2.3
by the way, the brakes will work REAL GOOD if you do try it.
