Help with spindle removal
smaug6
I am removing a front spindle on a 86 bronco II with auto locking hubs. I have everything off down to the spindle shaft and have removed the nuts holding the spindle. I can't get the spindle to come off. I have tapped it as the manual says but no dice. Any help would be appreciated.:icon_confused:
dennis461
Waterford, South Jersey
1991
Jeep
3.0l
does it look like this
first make sure the spindle nut is off, I'm not sure of your particular nut situation
I can send pics of how to do it.
Tapping won't work.
d
edit
You may need to get a very sharp chisel and start working around the perimeter to break it free.
Just hit the chisel a few times, then move a little, hit again.
Clean all the rust off with electric wire wheel so you can see where the spindle and knuckle come together. Look for the "parting line".
Do not try to drive this deep into the parts, just enough to get it moving out.
Wicked_Sludge
43
Westport, WA
3-point-GO
^ what is that?
i usually thread the spindle nut back onto the spindle and carefully smack that with a hammer. steel on steel produces the best jarring load...but if you wrap the nut with cloth you can wail on it a little harder without deforming the nut (check the nut often to make sure you arent damaging it).
if all else fails, heat can be applied.
smaug6
Thanks for the advice! I am not sure I can try this. There seems to be a flange around the spindle which is part of the knuckle. See Pics. Do you know of another way? Also I wonder if you know where I can buy a lock nut and key. I screwed up and forgot to remove the key and cracked the lock nut and destroyed the key. I think I can file the spindle threads and get that to work but I will need a new nut and key. See attached pics.
Wicked_Sludge
43
Westport, WA
3-point-GO
pic didnt work for me.
id hit the junkyard. you need the spindle nut from a truck with auto hubs...the manual hub spindle nuts wont work.
smaug6
This may be the best way to go in my situation. Do you know where I could get another nut and key?
smaug6
Thanks for the advice. I will try your method. I will call the junk yard. Much appreciated.
smaug6
Junkyard was the answer. I got the parts and put it all back togeather. Now the 4wd lights are flashing and she won't come out of 4wd. WTF????!!!!!
Wicked_Sludge
43
Westport, WA
3-point-GO
i think theres a bunch of info on how to test the 4x4 module in the tech library. flashing OD lights means theres a fault and the system cant shift into 4wd....most likely unrelated to your front end work.
